Re: Switch Left On / No Start
Posted by Tony on October 22, 2017 at 11:40:48 [URL] [DELETE] :
In Reply to: Re: Switch Left On / No Start posted by Charles (N.C.) on October 22, 2017 at 07:58:26:
I should have read you initial post more closely. Leaving the key on for even an hour so shouldn't fuse the points unless they were burned and on the verge of failing. Same for the coil. Takes while, (overnight will do it), to overheat and damage a coil. You have fuel, check for spark and troubleshoot as you would for any no start condition.
