Re: 601 idle adjustment
Posted by LeRoy on October 19, 2017 at 19:21:10 [URL] [DELETE] :
In Reply to: 601 idle adjustment posted by Richard NY 2N on October 17, 2017 at 17:16:33:
My 601 had a similar problem. I had to clean the throttle plate where the throttle arm joins the carb. linkage. This is probably not your problem. mine was pulling the throttle all the way down. You might try the idle adjustment screw on the carb.
L.O.L.
LeRoy
