601 idle adjustment
Posted by Richard NY 2N on October 17, 2017 at 17:16:33 [URL] [DELETE] :
My 601 has a 1100 rpm low throttle speed. If I push the linkage from the carb to the governor forward it will drop to 500 or so, but goes right back up when released. There wasn't a return spring on the bell crank so I added one. It looks like the rod from carb to governor needs lengthening to solve this issue. Has any one else had this issue? Thanks for your help.
