Ft. Mt. Dist. 8N
Posted by Charles on October 16, 2017 at 10:10:26 [URL] [DELETE] :
I was facing some serious work using the 8N I've set aside for work but,,,it let me down.This N "always" cranks right up with "no" choke.Does the job and returns to the shed.Not this time.Several turns of the engine and some choke but no start.Checked for spark but none.Golly,what has happened? I switched the dist.(and the coil spring screw)and it started right up ready for work.I've not checked for problem yet but I suspect points.Oh,,and I'm needing a couple of coil spring screws.Golly,,,where did I loose them.All has turned out well I'd say.
