Re: Paint prep on the 8n
Posted by TheOldHokie on October 11, 2017 at 15:54:44 [URL] [DELETE] :
In Reply to: Re: Paint prep on the 8n posted by Tom on October 11, 2017 at 13:16:27:
Get everything disassembled and ready to blast. Also be ready to prime within 24 hours after the blasting to prevent flash rusting. Then go rent a "small" tow behind compressor from a local rental center. My center charges $75/day for this 180 CFM compressor. Unless you have a pot large enough to do bridges it will run your blaster all day non-stop. You will run out of media nad/or eat up your nozzles before you run out of air. They typically rent with 50' of hose but you need to make sure you have the appropriate crowfoot coupler to connect it to your pot. Then have fun - not ;-)
TOH
