Re: Paint prep on the 8n
Posted by Jimmyjack on October 11, 2017 at 10:30:07 [URL] [DELETE] :
In Reply to: Re: Paint prep on the 8n posted by Bruce (VA) on October 11, 2017 at 10:15:04:
Electrolysis only works line of sight, and basically on rust. Great on smaller parts, but sheet metal is a bit more tricky. Depends too if their is any paint left or if it is solid rust. If you dont push the compressor and let it recharge you might get some use, if you have the pot try it. I also have a smaller quart size blaster that works quite well on smaller areas. Good old sandpaper will work also.
