Re: 2N charging system (again!)
Posted by Steve Frysinger on October 10, 2017 at 09:50:16 [URL] [DELETE] :
In Reply to: Re: 2N charging system (again!) posted by Tim Daley(MI) on October 10, 2017 at 09:03:17:
> My guy rebuilds starters and generators in a day and I get them back in 3 or less.
> He is a Ford guy and stocks a lot of the essential parts -armatures, field coils,
> brushes, and all the hardware. If you want him to rebuild yours, email for details.
YES, Please give me his contact info. I haven't found someone around here.
> What does ca. mean? calibrated? HHHMM. A digital meter will have a digital
> readout screen. An Analog meter has a multi-scale window with a needle.
I meant circa late '70s - I think I bought it at Sears in around 1976. It's definitely analog.
>You 'polarize' when battery is connected, but no power is applied (do not run
>tractor)using the crosswire/arc spark method.
Ignition ON or OFF?
>Polarization isn't the problem here. As soon as power is applied to the generator
>it becomes polarized, whether positive or negative.
Right, but other posters have said it could be reverse polarized and that would prevent it from charging my system. Not true?
>If it is a 3-brush generator, it will have the adjustment screw on the back end
>plate and I suspect it does. Do you see a screw terminal with an ARROW? I'm not
>sure if the new aftermarket ones have it or not.
I'll have to look when I get home.
>Get a good battery. Never use a "DEEP CYCLE" battery on these old tractors -not
>what they're made for.
Right, I didn't mean that I had used a deep cycle battery, only that because I have to charge in between uses it gets run down deeper than a normal battery is designed for (which can be hard on the plates. The battery does hold a charge though.
>Get a copy of JMOR's WIRING PICTORGRAMS downloaded and go thru all the wiring as
>I said with battery disconnected.
Will do.
>The AMMETER may not be wired correctly. Is it the original LOOP/INDUCTION style
>or a later aftermarket two-screw terminal style?
I've owned the tractor for ~30 years and have never replaced it, but I can't swear it's original. I'll look at the screws when I get home.
>Don't make any generator adjustments -let your starter shop guy tweak it all. Take
>generator, cutout, ammeter, and battery to him and he will bench test all fast,
>easy, and usually at no charge. If he doesn't know about old Ford stuff, find
>another one who does.
If I can find a local guy... So I shouldn't make the screw adjustment you mentioned in your earlier post?
>see if there is some info in my article you can use...
Downloading now...
Thanks!
Steve
