2N charging system (again!)
Posted by Steve Frysinger on October 09, 2017 at 19:32:24 [URL] [DELETE] :
Folks, I've run out of clues, or I wouldn't trouble you with yet another charging problem.
My old friend (~30 yrs) 2N (6volt) hasn't been charging for a long time. A year or so ago I raised this here, and after some diagnostics decided to replace the generator and cut-out. I did the cutout last year, but just got around to installing the generator (Yesterday's Tractors) a few weeks ago. That was an adventure, because the mounting bracket holes in its body weren't quite in the right place, but I managed.
Disconnected, I got some voltage out of the generator, though it varied wildly from nil up to 8 volts. (I took that variation to be a flaky meter connection, but maybe not?)
Since I had a pretty new cutout already, I tried connecting to the cutout, polarized, and started it up. No voltage on the generator stud, nothing on the ammeter, and no variation of the battery voltage with engine speed - stays at ~4 volts. I tested the continuity of the wire between the gen and the cutout, and it's good. So I decided to put in a NEW new cutout (since the previous was last year).
Still no dice, and now I don't show any voltage on the gen stud even disconnected. I can't believe something happened to the new gen, but if you think that's possible I'll take it off and do a motor test.
Other than that, is there something else I should try? Is there a way to test a new cutout on the bench to make sure it works? I bought two this last time, having read some folks' bad experiences with poor quality replacements.
Thanks much! Steve
