Re: 63 ,2000 air cleaner
Posted by WayneIA on October 05, 2017 at 09:40:38 [URL] [DELETE] :
In Reply to: 63 ,2000 air cleaner posted by Doug Siperly on October 04, 2017 at 21:53:29:
The 601 and a 2000 should be the same .The fuel tank on a 601 is longer than a 600 might be a problem. The 800 hood is mounted 2 inches higher than a 601. It will be a problem. All can probably be made to fit depended on your modifying abilities
