Re: 63 ,2000 air cleaner
Posted by Kirk-NJ on October 05, 2017 at 06:37:15 [URL] [DELETE] :
In Reply to: 63 ,2000 air cleaner posted by Doug Siperly on October 04, 2017 at 21:53:29:
The 600 and 601 should fit the 2000 with the tube if the engine is a 134. Some times they get switched out to a 172 engine. The early 800 should fit. later 800 might be the same but I not sure, the 801 had larger carb, bigger tube, bigger air cleaner/cup, different then the 600/601.
Kirk
