Re: 1953 Jubilee value with bad pinion
Posted by 36 coupe on September 30, 2017 at 07:56:52 [URL] [DELETE] :
In Reply to: 1953 Jubilee value with bad pinion posted by Josh Cronk on September 29, 2017 at 16:13:58:
If the housing is damaged a replacement is high priced and scarce.The part was used for 1953 only,it proved to be weak for the over head engine.I would take the top cover off before buying it.I chose a 640 when buying a Ford tractor because of the weak housing problem.
