Re: 1953 Jubilee value with bad pinion
Posted by Wayne N Ind. on September 29, 2017 at 19:27:20 [URL] [DELETE] :
In Reply to: 1953 Jubilee value with bad pinion posted by Josh Cronk on September 29, 2017 at 16:13:58:
I bought an 8n with the same problem for about the amount you said. I had another rearend swapped parts and it's being used everyday. Worked out good .
