8N Front mt. Points
Posted by Charles N.C. on September 25, 2017 at 11:42:36 [URL] [DELETE] :
I purchased a set of points for an 8N front mt. and a set for a side mt. some time back.I purchased these at NAPA local and for the life of me I can't get the front mt.to adjust the .015 setting.I've noticed the points will not allow the cam block to ride against the distributor cam.Seems to offset about 1/16in from the cam.The two mettle spring clips seem to be holding the block from the cam.These points look same as I had.I've had these for awhile and lost the receipt.I guess a new set is in order?
