Re: Carburator still drips fuel
Posted by NTP on September 23, 2017 at 00:37:29 [URL] [DELETE] :
In Reply to: Re: Carburator still drips fuel posted by Tim Daley(MI) on September 22, 2017 at 09:18:46:
It leaks from the weep hole. It does not have sintered bronze in the weep hole. It has the horse hair version. Tried both the old solid float valve and the new rubber tipped version. Both drip when the engine is not running. The venture will only fit in the bowl one way because of the different diameter flanges. Adjusting the float settings apparently changes nothing as far as the dripping is concerned. The N carb is a rather simple carb, but I'm missing something.
