Axle weights
Posted by Kirk-NJ on September 19, 2017 at 07:32:15 [URL] [DELETE] :
Got a set of axle weights from one of the guys from our show this past weekend. He said he took them off his 8n show tractor. I made him an offer and he bought them down the second day of the show. He said they were the flat top but when he bought them down I was pleasantly surprised to see they were the later style with the cut out so they will fit the hundred up thru the early thousand series. The later style was cut out to go over the axle bolt. The earlier style axle weight, both round tops and flat top would not fit the later tractors. I thought I would post a photo so if someone runs across them they will know what they fit. These are 140 lbs each and not for sale. I have only run across one other set to fit the later models in my area so they might be hard to come by. I have had other flat tops, 160 lbs, and other round tops, 180 lbs that fit the 9n/8n/2n and the early ferguson tractors.
