Re: '63 tug not starting
Posted by Doug on September 18, 2017 at 14:35:58 [URL] [DELETE] :
In Reply to: Re: '63 tug not starting posted by R Geiger on September 18, 2017 at 12:36:19:
it was the positive battery terminal. i assume it got hot because of a loose ground cable. i checked all the other connections coil, solenoid and ignition. all seem to be ok. ill try charging the battery i guess, it just seems weird that it was cranking fine before the positive battery terminal got hot.
