Re: 1951 Ford 8N
Posted by steveVa on September 15, 2017 at 15:35:56 [URL] [DELETE] :
In Reply to: Re: 1951 Ford 8N posted by Terry Huff on September 14, 2017 at 17:37:53:
Yes, but check it in gear too with both rear wheels jacked up. The shims need to be just right fot it to turn smooth in neutral and opposite you may also try having someone turn the other. If they are locked together then differential is locked up.
Some folks like that, but it makes it harder to turn wih my kubota..
