Re: 1951 Ford 8N
Posted by Terry Huff on September 14, 2017 at 17:37:53 [URL] [DELETE] :
In Reply to: Re: 1951 Ford 8N posted by steveVa on September 12, 2017 at 23:55:47:
Steve,,,
I jacked up the tractor put jack stands under it,,,,when I turn either wheel in the forward direction the other one turns the same way,,,,and if I turn one backwards they both turn the same way,,,,they should be going in opposite directions correct....so that tells me that the differential is not working correctly,,,right?
Thanks
Terry
