Re: where did the broken gear pieces come from in the clutch hou
Posted by Rustyal on September 09, 2017 at 23:56:04 [URL] [DELETE] :
In Reply to: where did the broken gear pieces come from in the clutch hou posted by Matt Prysock on September 09, 2017 at 19:31:53:
You may have a rod keep the engine from turning. But a valve could in theory. I've seen what your describing from a rod. The stuck valves are normally stuck open.
