Re: 841 Update - Starter?
Posted by Bruce (VA) on September 09, 2017 at 15:48:53 [URL] [DELETE] :
In Reply to: 841 Update - Starter? posted by John (AL) on September 09, 2017 at 15:31:55:
" The starter smokes when I push the start button"
" I put the tester on the starter side of the solenoid and it's showing 7+ volts. "
Your starter sleeps with the fishes.
Do NOT buy a new starter. Have yours rebuilt.
Iíve been working on old cars, trucks & tractors now for over 50 years. Whenever possible, I get OEM component parts rebuilt. Given the high probability that any new component part purchased for an N tractor is made somewhere overseas w/o adequate quality control, chances are very good that you will be disappointed. If you do not have a local rebuild shop, give these guys a call for a quote & shipping info:
Automotive Manufacturers Inc
2400 N Lombardy St Richmond, VA 23220
(804) 321-6861
They do mail order work. They rebuild carbs, clutches, pressure plates, water pumps, alternators, generators, starters & reline brakes.
