Re: Front Mount Distributor Ant Home !!!
Posted by Gaspump on September 08, 2017 at 17:03:59 [URL] [DELETE] :
In Reply to: Front Mount Distributor Ant Home !!! posted by Charles (N.C.) on September 07, 2017 at 16:08:03:
Ants can be real pests, got bit a few times by fire ants that invaded the sheet metal on my 960. Took about 20 seconds from start up to getting hit and one more for my egress! Then last week I installed a new GFI in by shop on the well house circuit as it was 20+ years with a weak spring that would trip frequently leaving the water softener system in-op. New one acted the same. Started opening things up in the well house and found a control box teeming with the little critters. Sure enough they were the cause of the GFI tripping.
