Re: Carb leaks
Posted by Rustyal on September 07, 2017 at 11:24:57 [URL] [DELETE] :
In Reply to: Re: Carb leaks posted by NTP on September 07, 2017 at 08:32:22:
Look at the part the rubber tip part fits into. It should have a gasket and be screwed down tight. You can try the rubber tip or the steel tip valve. It will not hurt to try.
