Re: Carb leaks
Posted by NTP on September 07, 2017 at 08:32:22 [URL] [DELETE] :
In Reply to: Re: Carb leaks posted by Rustyal on September 07, 2017 at 07:56:56:
The venturi will only fit one way if it is supposed to fit in the recess. The flange on the other end is too big to fit in the recess. I do have the 1/4 inch float setting. I did put in the new fuel inlet gizzmo with the rubber tip. Should I try using the old one, as new one has the rubber tip and may not be sealing properly.
