Re: Dearborn 14-16 moubt on Ford 600 and modications
Posted by Charles Krammin on September 07, 2017 at 08:08:20 [URL] [DELETE] :
In Reply to: Re: Dearborn 14-16 moubt on Ford 600 and modications posted by Tim Daley(MI) on September 06, 2017 at 05:35:09:
I use an adjustable sway bar on left, so no problem there. However I used the 8N fender mower break away mount (Dad put it on). The difference of right fender mount, probably explains why I need to extend the length of the break away (screw out). Currently the pitman bar runs close to the swivel of break away, on raised position. It appears the cutter bar is perdicular to the tractor movement.
Guess I'll lay a 2 X 4" under tractor, from front center, to rear center, and another 2 X 4 behind cutter bar and check for squareness. Is there another way?
Charles Krammin
