Re: Carb leaks
Posted by Tim Daley(MI) on September 07, 2017 at 07:49:04 [URL] [DELETE] :
In Reply to: Carb leaks posted by NTP on September 07, 2017 at 07:37:51:
I think you are looking at the other drain orifice, not on early TSX models. Leaking issue maybe a stuck float. Did you insert the Venturi the correct way? Did you set the float to 1/4" from gasket surface with the gasket on? SEE LINK...
