Re: Need help finding distributor parts
Posted by Tim Daley(MI) on September 04, 2017 at 17:46:54 [URL] [DELETE] :
In Reply to: Re: Need help finding distributor parts posted by Farmer Dan on September 04, 2017 at 13:59:21:
Dan-
I found all the parts at McMaster-Carr that will work. 8-32 x 3/8 Fillister Head Bras Screw at McMaster-Carr -SEE the LINK. The extra length won't hurt anything. Also, links to the brass washer and flat external tooth washer listed as well. The latter says thickness may vary from .025" to .039". Part spec shows thickness at .020". I really doubt the thickness will matter that much, especially if using the 3/8 long screw, but if so you can always hit them on your surface grinder. Since packages are in quantities of 100 pieces, maybe I will buy some of each from you.
BRASS WASHER:
https://www.mcmaster.com/#90114a546/=198pf5q
#8 EXTERNAL TOOTH WASHER:
https://www.mcmaster.com/#91114a009/=198plu2
