Re: idle mixture trouble
Posted by JohnB on August 31, 2017 at 07:21:42 [URL] [DELETE] :
In Reply to: Re: idle mixture trouble posted by Tony on August 31, 2017 at 01:51:53:
Great info here. I purchased all of my parts from Just 8N's. Wires are copper and I replaced all jets and adjusting screws. The old screws were mushroomed at the end from over-tightening.
The manifold looks like it has sat out in the rain for 750 years. It will definitely be a challenge to get it off without snapping the studs.
Compression checks out at 90-95 on all cylinders.
And yes, in the end, it does run great, doesn't hesitate, and makes good power. We'll see what challenges the manifold holds. If it's going to be more trouble than it's worth, then I may just the slight miss.
