Re: 8n hydraulic lift is very weak
Posted by JohnB on August 06, 2017 at 09:56:44 [URL] [DELETE] :
In Reply to: Re: 8n hydraulic lift is very weak posted by Tim Daley(MI) on August 06, 2017 at 06:43:20:
The only change I made using the Zane's jig was changing the position control nut about 3/8" (it was very close from the get-go) and the lift worked great before the pump sucked in part of the seal.
However, you bring up a good point: maybe it's worth double checking the adjustments. I'll re-read that section in the FO-4 manual.
