Re: 8n hydraulic lift is very weak
Posted by BlasterStumps on August 05, 2017 at 22:14:12 [URL] [DELETE] :
In Reply to: 8n hydraulic lift is very weak posted by JohnB on August 05, 2017 at 21:24:19:
first I would take a look at the cam follower pin. You should be able to see it through the inspect cover on right side using a light and mirror. If it is badly worn, may need to replace it.
