Re: Jubilee/NAA governor adjustment
Posted by Larry Holbrook on August 05, 2017 at 11:46:24 [URL] [DELETE] :
In Reply to: Jubilee/NAA governor adjustment posted by Will on August 04, 2017 at 23:10:48:
I don't believe there is an adjustment for the governor. It has a spring that has to be at the proper tension for it to work properly I do know that. I put a new spring on my 8N and it took a while to get the spring tension just right I remember that. I will look in my manual to make sure here in a bit. Someone more knowledgeable might kick in also.
