Re: Runs fine then dies after 10-15 mins
Posted by Bruce (VA) on August 03, 2017 at 23:22:51 [URL] [DELETE] :
In Reply to: Re: Runs fine then dies after 10-15 mins posted by michael on August 03, 2017 at 21:45:19:
Check out tip # 39. You have a 60+ year old tractor. Trying to work on it w/o the manuals is not fun.
See tip # 45; there are 3 fuel screens you need to check.
Start w/ the screen in the brass elbow at the carb. (see tip # 56) Then check the screen in the top of the sediment bowl. (see tip # 70)
If that doesn't fix the problem, then it's time to remove the sediment bowl for a good cleaning of that screen.
