Re: 9NBN
Posted by Kirk-NJ on August 03, 2017 at 05:37:38 [URL] [DELETE] :
In Reply to: 9NBN posted by Kent S. on August 03, 2017 at 00:37:51:
Here is one I found for Bob Johnson AKA Paladin (Bob in Pa). You might want to do a search and try to email him. If I remember correctly from when we picked it up the side pieces were 4" channel. You can't really see the back because of the welded plate on top.
If I remember correctly it had a front mounting plate similar to the mount plate on my winch tractor and was mounted in the rear under the axle using the lower arm 3pt connection.
You would probably have to weld up some angles on wider channel for the back and front.
Kirk
