Re: Runs fine then dies after 10-15 mins
Posted by Bruce (VA) on August 02, 2017 at 12:54:11 [URL] [DELETE] :
In Reply to: Runs fine then dies after 10-15 mins posted by fuesselfc on August 02, 2017 at 11:56:41:
You need to answer 2 questions before you do anything else:
With the bolt in the carb bowl removed and the gas on, will the fuel flow fill a pint jar in less than 2 minutes?
Next, get out your adjustable gap spark checker * , open the gap to 1/4", hook it up, turn the key on and crank the engine. Does the spark jump 1/4"? Post back with the answers.
And do not buy a new part for the tractor until you can answer this question: how do I know the part on the tractor is defective? Replacing the oem fuel line with a rubber one and an in-line filter has just created a new set of problems for you; see tip # 15. Resist the temptation to fix things that are not broken.
* Don't own an adjustable gap spark checker? Buy one! Not a test light! Until then, take an old plug, open the gap 1/4" ground it to the head & look for spark. Itís not the color of the spark that counts; itís the distance it jumps.
