Re: Hydraulic lube
Posted by Tim Daley(MI) on July 31, 2017 at 13:06:35 [URL] [DELETE] :
In Reply to: Re: Hydraulic lube posted by Jim Hay on July 30, 2017 at 20:55:04:
yes, meant to say 4 bolts secure the cylinder to the top cover...
If you mean the valve chambers, again, the only lube comes from the system itself. There are no parts that require special lubrication or servicing. All 'the manuals' would've told you don't you think? I've never seen a frozen PTO Shift Lever but I guess some of you have. I suppose if a tractor was setting in a field for 50 years everything would be rusted up and the PTO shaft would not be my first priority...
