Re: 9n won't start think its the starter hi current switch
Posted by Dan Chisler on July 31, 2017 at 12:14:45 [URL] [DELETE] :
In Reply to: Re: 9n won't start think its the starter hi current switch posted by BlasterStumps on July 30, 2017 at 22:14:08:
@ month old bat ----new heavy gauge cables ---no corrosion ---engine Should not be seized i will check ran fine last turn off ..I am hopeing its the selinoid i did change it out with an old one ..No load when checked bat . I just put the bulb hydrometer in each cell and it went to the best side of the green all cells . I will check the by jumping the selinoid also see if motor is easy to hand turn .Thanks
