9n won't start think its the starter hi current switch
Posted by Dan Chisler on July 30, 2017 at 20:38:12 [URL] [DELETE] :
farmer Dan here yet again with the gruesome twosome 8n & 9n The 9n just clicks now even tho the bat has just been charged and shows full charge with bat tester . I am suspecting the hi current switch and will try to bypass that and see if that is the problem .I has a two month old starter and every wire on the rig has been replaced with the correct wire gauge also brand new heavy gauge bat cables .
