Re: tandem trailer
Posted by Kirk-NJ on July 28, 2017 at 11:08:01 [URL] [DELETE] :
In Reply to: tandem trailer posted by scott McKinnon NC on July 27, 2017 at 17:07:49:
I agree with others on the trailer being too small to move the tractor to adjust the weight. If it was just the tractor it would be no problem cause you would have the room to move back and forth.
Some thing else to consider which a lot of car trailers don't have is some way to suppose the rear when loading which causes stress on the axle brackets and where its connected to the front ball hitch. Most equipment trailers have something built on the ramp to support it when loading. My trailer has a leg that drops down. In the up position it also helps support the ramp and you get a lot less noise when driving. Systems like these can also be added if your trailer doesn't come with them.
Kirk
