LOOSE SEAT
Posted by joe in wilkinson on July 26, 2017 at 16:27:26 [URL] [DELETE] :
1949 8N169650 The seat is very loose. I need part numbers and source to purchase. I have a parts book, but it only has the U shaped leaf spring. My 8N has the big coil spring directly under the seat and a small shock absorber. At the front hinge point there is a pin with rubber bushings on each end that goes in a tube and a fine thread bolt that goes in each end. I need:
1. The hinge pin
2. Two rubber bushings
3. Two rubber bushings that go in the the lower mounting of the shock absorber.
N-Complete used to be 1/8 mile down the road from me, but now has moved to Mount Summit, IN. I have their parts book, but they do not show these parts.
