Re: Steering box
Posted by BlasterStumps on July 21, 2017 at 23:15:03 [URL] [DELETE] :
In Reply to: Steering box posted by Rod-MI on July 21, 2017 at 18:46:23:
probably some worn seals but I'm wondering if it was hot outside where you were using the tractor? When I put cornhead grease in mine, it was okay until I took the tractor out in the hot sun. After a while oil started coming out from several places and ran down onto the housing. It kept coming out for a couple days and finally it stopped. The cornhead grease didn't come out, just the old oil that was in there to start with. I'm not sure but I was thinking temperature was behind the oil coming out. I'm sure the seals are worn in mine.
