Re: More questions about my Sherman
Posted by Kirk-NJ on July 20, 2017 at 08:19:11 [URL] [DELETE] :
In Reply to: More questions about my Sherman posted by dave#1 on July 20, 2017 at 07:40:33:
I use the standard range when mowing. Use the low range for most of the flat belt work, planting, and in reverse and hooking up implements. I have use the high range on tractor drives and on the road but not much.
You'll find you'll use it more when you need an in-between gear
