need some info on bearings
Posted by BlasterStumps on May 18, 2017 at 17:38:57 [URL] [DELETE] :
I have some Norma 203PP bearings, (2) that I am wanting to find good quality replacements for. they are apparently the same as these:
Timken 203PP Ball Bearing, Double Sealed, No Snap Ring, Metric, 17 mm ID, 40 mm OD, 12 mm Width, Max RPM, 1060 lbs Static Load Capacity, 2450 lbs Dynamic Load Capacity.
I found the Timken info on Amazon but they are almost $20 per bearing. Anyone have a line on a source for similar bearings where I can get them at a little less?
chiseler Mike
