Re: If I knew the dimensions...
Posted by Gaspump on May 17, 2017 at 16:40:01 [URL] [DELETE] :
In Reply to: If I knew the dimensions... posted by BlasterStumps on May 16, 2017 at 15:39:24:
The Old Hokie has trans and hyd plugs correct. The engine oil is 3-1/16" OD and 2-5/8" ID. Both my engine and gear lube gaskets are 1/16" thick. The gaskets can be a little loose once over the threads but I just grip the plug by the flange and gasket being certain to center the gasket and once hand snug just tighten it tad with a wrench.
