Re: 1939 Ford 9N Tractor
Posted by Tim Daley(MI) on May 17, 2017 at 06:43:15 [URL] [DELETE] :
In Reply to: Re: 1939 Ford 9N Tractor posted by Jim Mortensen on May 16, 2017 at 20:30:58:
Yep, it has an 8N block/engine that was swapped out.I see an 8N badge, 8N doglegs, an 8N air cleaner, 3-wire 8N generator, and 16" 8N Front wheels and tires. 39 9N parts: double ribbed fenders, key switch on right side dash, starter button on left side dash, ignition "ON" lamp below ammeter, but it may be a 39 steel hood -hinged battery access door doesn't fit right -snap -in cover was original. Is radiator 9N big square one? Serial number??? ALL N gas tanks had the vented bubble on top. Is your starter button on top of shifter case or on dash?
