If I knew the dimensions...
Posted by BlasterStumps on May 16, 2017 at 15:39:24 [URL] [DELETE] :
I got a new toy. I have it chucked up in my brace drill in the picture. It works as a gasket cutter so I would like to try cutting some for my tractors. I'm thinking it will allow me to cut drain plug gaskets for the housings and the engine. Also think I will try a couple for the gas cap. I can do the gas cap okay but I don't have the dimensions for the drain plugs. Not sure if the engine drain plug takes a different size than the trans and hydraulic housings. Anyway, if someone has those dimensions, I would be grateful if you would be willing to share such with me. If I can get the dimensions, I will give them a try. Soon as I get over the dag-blasted stomach flu that is.
