Re: Starting my 8N
Posted by Bruce (VA) on May 16, 2017 at 07:40:01 [URL] [DELETE] :
In Reply to: Re: Starting my 8N posted by doug on May 15, 2017 at 15:20:14:
Did you check the battery? A hydrometer is best, but even a voltage test is helpful. You should see 6.35 volts 24 hours after you take it off the charger.
Yes, loosen the starter and polish the mating surfaces; see tip # 36 first.
And do clean both ends of both cables.
