Re: Starting my 8N
Posted by Bruce (VA) on May 14, 2017 at 21:53:42 [URL] [DELETE] :
In Reply to: Starting my 8N posted by Doug on May 14, 2017 at 21:37:14:
Does it start?
Once you confirm the battery is good (see tip # 50) you need to check out the entire starting circuit.
In addition to charging & checking the battery, chances are you need new cables as well (tip # 41). And, don't forget to clean all the grounds, to include the mating area between the starter & the block.
If that does not work, time for a voltage drop test.
