Re: Need Help on Ford 172/192 CI Industrial
Posted by Jon Rhee (RI) on May 13, 2017 at 22:06:55 [URL] [DELETE] :
In Reply to: Re: Need Help on Ford 172/192 CI Industrial posted by Bruce Dorsi on May 13, 2017 at 21:47:44:
Vent hole....possibly. I painted the carb so its possible I plugged it up. Wouldnt that be a lean situation though? I thought about the ignition too but it starts up on half a roll every time. The behaviour does seem like ignition is intermittent.... kind of like someone is turning the key off and on before the engine quits. I will check both of those things Thank you Bruce!
