Re: Need Help on Ford 172/192 CI Industrial
Posted by Jon Rhee (RI) on May 13, 2017 at 19:08:23 [URL] [DELETE] :
In Reply to: Re: Need Help on Ford 172/192 CI Industrial posted by Dean on May 13, 2017 at 17:40:20:
Hi Dean -
Im testing it without the air intake connected to the carb. The fuel is good, and I am using a test bottle to feed it. I was hoping to get it warmed up so I can torque the head down.
I didnt mess with the distributor, the timing or the valves and when I pulled the rocker arm off and pushrods I labeled them all so theyd go back in the sane spots.
I'm hoping I'm correct in assuming that because I have veey good even compression that there os nothing catastrophic wrong. Maybe a gasket leak on the intake side?
