Re: Hydraulic Lift,,,again !
Posted by Charles(N.C.) on May 12, 2017 at 10:13:25 [URL] [DELETE] :
In Reply to: Re: Hydraulic Lift,,,again ! posted by JMOR on May 11, 2017 at 16:37:43:
Yep,,I have the IT FO4 Repair manual.It's about worn out.When the control arm is pushing the intake valve in this means the pump is calling for fluid??? Somehow it appears the pump isn't pumping enough pressure fluid to raise the arms.This tractor sat under a shelter for about 3yrs. without moving but it had been taken to shows and lift worked.No water in the fluid but still the intake valve was stuck.I'm guessing I'll have to pull the pump "AGAIN" for an inspection when I feel better.I'm thinking it might need a pro to refurbish it for me.??? Thanks fellas.
