Re: Front mount coil
Posted by Bruce (VA) on May 12, 2017 at 07:34:08 [URL] [DELETE] :
In Reply to: Re: Front mount coil posted by Bob E on May 11, 2017 at 23:15:20:
There is a difference between what you said yesterday: " Problem was still lack of power on acceleration, some back firing, seemed to run better at full throttle then half." and what you said today: " the tractor ran great for the first 30 to 45 minutes, then there was some hesitation followed by lack of power at all RPM's"
Maybe the difference is that I misunderstood you.
This is what I suggested: " If the tractor starts & runs fine for 30 minutes or an hour then cuts off & refuses to re-start, and you checked for spark at the plugs & it had no spark at all, AND you have the correct voltage at the coil thatís a good sign that you have a bad coil. Let it cool off, restart it & if you have a good spark, odds are itís a bad coil. "
Did you check for spark as soon as it stopped running?
Yes, you could have a defective coil......you could also have a defective ignition switch too as steve va pointed out. (see tip # 50)
Save the "defective coil". Next hot day when you feel like fooling w/ it, put it back on the tractor.
